Thu Oct 13, 2011 3:08 pm
Hi,
I just received my first Einstein flash. Everything works fine but there is kind of a "buzzing" sound coming from the modeling lamp as long as it is turned on. As soon as I turn off the modeling lamp the fan is all there is to hear. Is that okay? I'm from Germany using 220V.
Thanks in advance!
Regards,
Michael
Thu Oct 13, 2011 4:38 pm
That is not uncommon, particularly if the lamp is dialed down. Regular incadescent lights will do this in the home too if on a dimmer switch.
Thu Oct 13, 2011 4:55 pm
Thanks for the fast reply! I'm currently using Aurora Fusion Flashes and their modeling lamps do not produce any noise. So I was just wondering if everything is okay with the Einstein.
Regards,
Michael
Sat Nov 19, 2011 9:05 am
Michael and PCB Tech -- I just noticed the same buzzing noise from the modeling lamp on my Einstein640 as well. I just brought it over from the U.S. (120v/60hz to Germany 220v/50hz) but don't remember it making any noise like this before in the states. The buzzing is consistent from minimal to full power.
I was wondering if the bulb needs to be changed because of the power difference?
(I've learned by popping a couple 110v house bulbs accidentally into my 220v sockets!)
The buzzing just doesn't sound good and is a bit annoying without some music on in the studio.
PS: I'm SO happy the Einstein640 is designed to be internationally friendly, with 95 to 265 VAC power and the 2.4ghz wireless CyberSync/CyberCommander system! =)
Sat Nov 19, 2011 4:53 pm
There is no need to change bulbs due to mains voltage. This is automatically regulated in the light.
Sat Nov 19, 2011 11:53 pm
It's likely the lamps will buzz more at 230V because the amount of dimming is much greater due to the bulb receiving pulsed 230V instead of pulsed 120V.
