Sat Oct 15, 2011 11:04 pm
Just received two Einstein units, including a cyber commander and two CSXCV's. Both units were working fine for +-35-40 flashes. The modeling lamp on #2 was originally set at 'sync model power with flash output'. At random it bumped the lamp to about 1/2 power and will not turn off. It will increase in output to full, but will not go below half power. Thought it might be the CC so I removed its battery. Also removed the CSXCV with no change. Also unplugged power from wall outlet for +-30 seconds. The flash appears fine. One other comment, the modeling lamp power bar stays about 2 stops below the flash bar when you adjust the flash output. Not sure what to do next? I read a similar post where it could be related to a pocket wizard, but since I have a CC I'm not sure. The other Einstein appears to be working fine (for now). Thanks for your help in advance.
Sun Oct 16, 2011 12:07 am
After removing the CSXCV and leaving it out did you press the easy set button to see if everything returned to working order?
RMS
Sun Oct 16, 2011 9:55 am
Pressed easy set wo/ CSXCV... no change in modeling lamp. Does reset other functions like its supposed to. Any other suggestions???
Mon Oct 17, 2011 4:40 pm
This unit will have to come in for service.
Users browsing this forum: No registered users and 97 guests
