Tue Jan 19, 2010 2:45 pm
I am shooting a lot on a black background. I have a 36" softbox, umbrella fill and hair light in a snoot above.
Here's my problem: I have two accent flashes in snoots off to the sides and behind the subjects. The snoots are clearly not the right modifers. They spill onto the black background that I am trying to keep black.
I'm thinking that gridspots might be the answer, but I've never worked with them. Do the the honeycombs come in different apertures or are the holes all similar with only different size outside diminsions?
You guys have come a long way since I read that light blue pamphlet eons ago. Keep up the good work.
-Marlin
Tue Jan 19, 2010 3:36 pm
to get a low-key, use the directional lights, take pictures in a large, dark studio (if the studio is not big, the walls and ceiling should be dark gray)
Forget about the umbrellas and softboxes. Use reflectors with honeycombs and barn-doors, snoot
put the model as far as possible from the background!
If you need to use soft light use soft-box (or strip-box is better more directional light and more controllable) with a honeycomb, but in this case, your studio should not be less than 100 square meters.
In soft-boxes you can remove the outer cone (diffuser).
during the post-processing of photos enhances contrast
excuse for my terrible English! At school I studied French =)
Tue Jan 19, 2010 4:42 pm
snoots should be fine, however, that depends on where you aim them. Umbrellas are less desireable, as they spread light everywhere, particularly shoot thrus. Grids for the softbox will help keep light from spilling. Keep the subject as far from the back ground as possible, and the lights as close to the subject as possible. This maximizes the light fall off to your advantage.
TS
Fri Jan 22, 2010 5:48 am
I agree that umbrellas should not be used for low key work. (I shoot a lot of low key too.)
Think of an umbrella as a shotgun compared to a softbox or grid being a rifle. The umbrella throws light everywhere and is hard to control. Most likely your black background is being lit by your umbrella fill.
I have one of the Paul Buff snoots. If you do too then you are already using a grid. That is because the Buff snoot is simply a grid with a round piece of metal on the front constricting the light to a small circle. Frankly, I would never use a snoot for portrait work as they are much too directional. I find the grids work better. My suggestion would be to buy the set of 4 grids for around $100 USD and get to know which ones you like. Then buy more of that one.
The big problem I have with low key in my small studio (see my website section "Products" then move down to the last photo) is spill from the lights. So next to each light I have a second light stand holding a 20x30 inch black Foamcore panel. These were purchased for about $7 USD each from Office Depot.
Often I will bounce a strobe off one of the white walls of my studio but I will put a piece of black Foamcore on each side of the strobe. This way the bounced light will not hit my backdrop.
If you have a softbox and on the front edge there are strips of Velco sewn on you are in luck. Take a look on eBay for "honeycomb panels" or "grids" for your soft box. These are a set of long thin black strips connected with fabric. When attached to the front of your softbox they restrict the light coming out to a narrow angle. There are two designs. One is a set of strips which are all parallel. (Think of Venetian blinds you might have seen in people's homes.) The other design is made with strips running in both directions so you end up with a grid. This design restricts your light output even more to be quite directional. The one I use is the first type with just the strips running in one direction: |||||||||
Take a look at my website under the section "Headshots" or "Portraits/Adult". There you will see a low key portrait of Marek Kedzierski, a theatrical director from Poland who was in Atlanta for a couple weeks. I created his portrait with two of my 800WS Alien Bees. Each had a grid over the reflector. (I don't remember which grids.) One light was about 20 feet behind his right shoulder (camera left) just barely illuminating the back of his head and his right ear to keep them from merging with the black area behind him. The second light was actually aimed at a white piece of theatrical fabric which was right next to my camera. Only the edge of the grid-restricted light was hitting his left ear, the majority of the light was reflecting back to illuminate his face. This sort of lighting is quite contrasty and looks like spot lights used by Hollywood photographers of the 1930s (a look I was trying to emulate). I used Irfan View to convert the RAW file to monochrome (B&W) then forced the image to be red. This simulates the look of orthochromatic film which was what they had in the 1930s. Finally I used Irfan View to adjust contrast and density to what you see on the website. This technique works for men with character lines but I would NEVER do it to a woman as every line, crack and mark on her skin would show up!
Hope this helps you.
Terry Thomas...
the photographer
Atlanta, Georgia USA
www.TerryThomasPhotos.com
Fri Jan 22, 2010 10:29 am
If you are interested in grids for one of our foldable softboxes, we carry them as well.
http://www.alienbees.com/softboxes.html second section
TS
Fri Jan 22, 2010 10:54 am
Just to be clear. I doubt you have 800 watt/second Alienbees.
AB400 = 160 watt/seconds
AB800 = 320 watt/seconds
AB1600 = 640 watt/seconds
Thanks for all the other info, it is very interesting!
