Sun Jan 24, 2010 4:30 am
I noticed while researching flash duration for my AB 1600 that there is mention of t.1 and t.5 method and depending what method you choose, decides how long your flash duration is. Can someone describe what this is and how you choose on the unit the method you want? I looked through the manual (quickly albeit), searched the FAQs here and older threads and could not find what I was looking for. Thank you so much!
-Dustin
Sun Jan 24, 2010 7:24 am
They aren't settings on your flash unit, they are two different measurements of flash duration.
The output power you choose for the flash will affect the t.1 and t.5 times for your flash.
Here is an article about flash duration, that explains t.1 and t.5:
http://www.sportsshooter.com/news/1888
Sun Jan 24, 2010 4:17 pm
See
http://www.paulcbuff.com/forums/viewtopic.php?f=5&t=59
Users browsing this forum: No registered users and 20 guests
