| Question on wireless remotes http://paulcbuff-techforum.com/viewtopic.php?f=8&t=21 |
| Author: | Rick [ Fri Dec 11, 2009 2:32 pm ] |
| Post subject: | Question on wireless remotes |
I'm planning on purchasing the "Busy Bee" lighting package. I don't want a lot of extra cords running around my studio so instead of getting the wired remotes, I'm looking at deleting that from the package and purchasing one CST and one CSR+ which I will attach to my main light. If I set the other lights up to be slaves, will this set up work in most instances? Or, is it better to have a CSR+ unit for each of the 4 lights in the kit? |
| Author: | dmward [ Fri Dec 11, 2009 2:38 pm ] |
| Post subject: | Re: Question on wireless remotes |
My preference is a CS+ remote for each light. The optical slave in the light is reliable, providing it sees a flash. The only time I've had trouble was when the back of a light was near a window so that the outside light "blinded" the sensor. With the CS+ you also get the capability to do power adjustments etc. via the Cyber Commander. And using its light meter function you can create a profile for the light(s) based on the set up. Very powerful capabilities. I am reading and digesting the CC manual in anticipation. |
