| New Vagabond Mini 230v does not work http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2450 |
| Author: | agg [ Mon Oct 17, 2011 3:34 pm ] |
| Post subject: | New Vagabond Mini 230v does not work |
Hello! I am from Ukraine. I have a problem with my new VML 230v. After first recharging the battery until the all Lead Light turned GREEN, I tested it with my Einstein and after series (near 50-70) flashes with different power output Led Light turned to yellow. After it turn to green Einstein steel does not work from VML at all. Einstein works normal from ordinary electrical outlet. Fuse on VML is ok. Battery is ok. But when VML turned on It turn very hot in 5 minutes without any load and cooler is turn on. What should i do? I hope this is nothing serious. Thanks. |
| Author: | Technical Support [ Mon Oct 17, 2011 5:51 pm ] |
| Post subject: | Re: New Vagabond Mini 230v does not work |
If the VML is noticeably hot and the internal fan starts in less than five minutes after switching it on with no load then customer service needs to be contacted ASAP. This is assuming the VML was not hot from an earlier test. |
