Tue Nov 01, 2011 3:56 pm
can not get my 650s to hypersysnch with flex tt1 system. did the firmware update. when i go above synch speed for nikon d3 i get a black screen. :?:
Tue Nov 01, 2011 4:22 pm
viewtopic.php?f=8&t=66
viewtopic.php?f=8&t=67
viewtopic.php?f=8&t=1844&start=0&
http://www.pocketwizard.com/inspiration ... nc_fpsync/
The above links detail sync speed, high sync speed, hypersync and how it interplays with Einstein. It is a very complex explaination that cannot be fully repeated everytime the question is asked. However, the first thing to try is setting Einstein to full power.
Tue Nov 01, 2011 4:40 pm
Technical Support wrote:
http://www.paulcbuff-techforum.com/viewtopic.php?f=8&t=66
Tried to set to full power, nothing happens
Wed Nov 02, 2011 9:30 am
What firmware version is in the MC2? Should be 2.200
Wed Nov 02, 2011 9:34 am
Also, make sure it says CTL-01 on the back LCD instead of CH-01 for the channel display. You need to be using the ControlTL (CTL) channels, not the legacy PocketWizard channels (CH) (which would make the flash fire when using a Plus II).
And make sure the firmware in your triggering radio is updated to the latest (6.0 for Canon, 3.003 for Nikon).
