| will pocketwizard ac9 alienbees adapter work on zeus packs http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2490 |
| Author: | Phillip2446 [ Fri Nov 04, 2011 2:01 am ] |
| Post subject: | will pocketwizard ac9 alienbees adapter work on zeus packs |
i just read that the ac9 alien be adapter with the TT5 allows remote power control of AB or WL. will this work with the Zeus power packs as well? http://www.pocketwizard.com/products/tr ... 20adapter/ thanks phil |
| Author: | Technical Support [ Fri Nov 04, 2011 9:05 am ] |
| Post subject: | Re: will pocketwizard ac9 alienbees adapter work on zeus packs |
Zeus has the RJ11 connection that Alien Bees have and is designed the same way. I would assume it works for Zeus, but you would get a more accurate answer from Pocket Wizard. |
| Author: | RickUrb [ Sat Feb 25, 2012 9:49 am ] |
FYI: I just found this on the Pocket Wizard website. AC9 AlienBees Adapter Compatibility COMPATIBILITY The AC9 AlienBees Adapter is compatible with the following Paul C. Buff Flashes: AlienBees White Lightning X-series, UltraZAP or Ultra flashes including: Zeus Power Packs B400 X800 Z1250 B800 X1600 Z2500 B1600 X2400 X3200 UZ800 UZ1600 Ultra60 Ultra1200 Ultra1800 |
