| CyberSync Problem http://paulcbuff-techforum.com/viewtopic.php?f=8&t=250 |
| Author: | kenbulmer [ Tue Feb 09, 2010 2:13 pm ] |
| Post subject: | CyberSync Problem |
I'm having a problem with my CyberSync hot shoe transmitter. Seems like there's some kind of a short or something and it just starts rapidly firing. If I fiddle with it for a while it will stop but sometimes just touching it the wrong way will cause it to start again. Does anyone know if a low battery might cause this? I've had it about a year and have maybe only used it for 20-25 shoots. Any other ideas on what I could try to make it stop without ripping it apart? Ken |
| Author: | Technical Support [ Tue Feb 09, 2010 2:41 pm ] |
| Post subject: | Re: CyberSync Problem |
Yes, a low battery can cause this. press the test button and see if its LED blinks. Muliple blinks or no blinks are indicators of a dead/dying battery TS |
| Author: | kenbulmer [ Tue Feb 09, 2010 3:07 pm ] |
Thanks - I'll replace the battery and see if that helps. Any idea if I can get a replacement battery at some place like Radio Shack? |
| Author: | Technical Support [ Tue Feb 09, 2010 4:11 pm ] |
Radio Shack should have them, as well, Walgreens is a good source, too. TS |
| Author: | kenbulmer [ Wed Mar 10, 2010 8:08 am ] |
Forgot to post back. New battery did the trick. Works just like new. Thanks so much. Ken |
