Thu Nov 10, 2011 10:24 am
What speedring for profoto 1x6 strip box?
Jim
Thu Nov 10, 2011 10:53 am
I preume you are mounting the Profoto softbox to a Paul C. Buff light? If so, our LGSR http://www.paulcbuff.com/speedrings.php (3rd item) will probably work. While this is the most common outer diameter speed ring size, it is by no means a standard. Profoto may have a Balcar mount speed ring as well. We have not tested any Profoto softboxes, so we cannot make any specific recommendations.
Thu Nov 10, 2011 10:58 am
Thanks.
Jim
Wed Nov 16, 2011 5:54 pm
Jim Sanderson wrote:
Thanks.
Jim
Jim,
Check the diameter of the adapter in the speedring. If its 6.125" then the adapter ring that Jerry Kacey makes will fit. Its a very nice ring because its flat and lets the Einstein flash tube sit more into the modifier.
Thu Nov 17, 2011 10:39 am
Also consider a Bowens Quickring w/ a Balcar insert. If you've never tried a Quickring, you're in for a treat :-)
Users browsing this forum: Google [Bot] and 53 guests
