| What Speedring http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2501 |
| Author: | Jim Sanderson [ Thu Nov 10, 2011 10:24 am ] |
| Post subject: | What Speedring |
What speedring for profoto 1x6 strip box? Jim |
| Author: | Technical Support [ Thu Nov 10, 2011 10:53 am ] |
| Post subject: | Re: What Speedring |
I preume you are mounting the Profoto softbox to a Paul C. Buff light? If so, our LGSR http://www.paulcbuff.com/speedrings.php (3rd item) will probably work. While this is the most common outer diameter speed ring size, it is by no means a standard. Profoto may have a Balcar mount speed ring as well. We have not tested any Profoto softboxes, so we cannot make any specific recommendations. |
| Author: | Jim Sanderson [ Thu Nov 10, 2011 10:58 am ] |
Thanks. Jim |
| Author: | dmward [ Wed Nov 16, 2011 5:54 pm ] |
Jim Sanderson wrote: Thanks. Jim Jim, Check the diameter of the adapter in the speedring. If its 6.125" then the adapter ring that Jerry Kacey makes will fit. Its a very nice ring because its flat and lets the Einstein flash tube sit more into the modifier. |
| Author: | kenyee [ Thu Nov 17, 2011 10:39 am ] |
Jim Sanderson wrote: What speedring for profoto 1x6 strip box? Also consider a Bowens Quickring w/ a Balcar insert. If you've never tried a Quickring, you're in for a treat :-) |
