WL Ultra 600 - No ready light after long non-use
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2503
Author:  mlhonradojr [ Fri Nov 11, 2011 8:11 pm ]
Post subject:  WL Ultra 600 - No ready light after long non-use
I have an 20-plus years old Ultra 600 that hasn't been used for over a year. When I recently turn the power on the green ready indicator doesn't light up. However, the test button pops the flash and all other controls seem to work, i.e., pops on slave mode or synch-wired, modeling lamp turns on, flash power has no issues. Can I/should I do anything about it? My other flash is an Ultra 1200 with no issues and the green ready light works like a charm.
Author:  Technical Support [ Mon Nov 14, 2011 12:17 pm ]
Post subject:  Re: WL Ultra 600 - No ready light after long non-use
It has been our experience that if the green LED is not on, the light will soon fail. Be sure, however, the LED is actually visible in the back panel, and has not been pressed into the light and cannot be seen. Should you need service, please contact us to discuss your options.
