| Using Alien Bees Transmiter or Cyber Commander w/ Canon G12 http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2516 |
Page 1 of 2 |
| Author: | princer7 [ Thu Nov 17, 2011 3:35 pm ] |
| Post subject: | Using Alien Bees Transmiter or Cyber Commander w/ Canon G12 |
Thought I would test out my Canon G12 with the Cyber Commander for an alternative way of shooting the AB800's. No joy . It will fire a Canon 580EX II without any problem but does not seem to trigger my strobes. I have tried both the Cyber Commander as well as the Transmitter. Anyone else try this? What have been your results? |
| Author: | kenyee [ Thu Nov 17, 2011 3:50 pm ] |
| Post subject: | Re: Using Alien Bees Transmiter or Cyber Commander w/ Canon G12 |
FWIW, folks in the flickr strobist forum have used the CST w/ the Canon Gxx cameras and reported high sync speeds...not sure what the issue is w/ yours though... |
| Author: | princer7 [ Thu Nov 17, 2011 4:12 pm ] |
Maybe my settings are wrong for shooting with the camera body. I set it to the same as my Canon 7D - ISO 100, Manual, F 8.0, 1/250 |
| Author: | Technical Support [ Thu Nov 17, 2011 4:58 pm ] |
kenyee wrote: FWIW, folks in the flickr strobist forum have used the CST w/ the Canon Gxx cameras ... While a G9 will be very similar, it does not mean the same as a G11 or G12. I am not saying this is or is not the case, but... |
| Author: | Technical Support [ Thu Nov 17, 2011 4:59 pm ] |
princer7 wrote: Maybe my settings are wrong for shooting with the camera body. I set it to the same as my Canon 7D - ISO 100, Manual, F 8.0, 1/250 I presume this means the CC worked fine on a different body? Try pressing down on the CC while trying to take a photo. This will force the foot down incase it is not making contact. |
| Author: | Technical Support [ Thu Nov 17, 2011 5:01 pm ] |
Also, turn live view off and use the viewfinder to see if this makes a difference. It can on Canon DSLR's. Also try toggling the flash mode to/from manual and auto. |
| Author: | princer7 [ Thu Nov 17, 2011 5:21 pm ] |
Technical Support wrote: princer7 wrote: Maybe my settings are wrong for shooting with the camera body. I set it to the same as my Canon 7D - ISO 100, Manual, F 8.0, 1/250 I presume this means the CC worked fine on a different body? Try pressing down on the CC while trying to take a photo. This will force the foot down incase it is not making contact. I have used the Cyber Commander successfuly with the Canon 7D and 50D with the light setup the same way. I'll give your suggestion a try to see if it is a contact problem. |
| Author: | princer7 [ Thu Nov 17, 2011 6:02 pm ] |
Technical Support wrote: Also, turn live view off and use the viewfinder to see if this makes a difference. It can on Canon DSLR's. Also try toggling the flash mode to/from manual and auto. Turning off the display seemed to have done the trick. Thank you for your help. |
| Author: | Technical Support [ Thu Nov 17, 2011 6:06 pm ] |
There may be a menu option to allow LCD screen to be used. |
| Author: | c2thew [ Thu Nov 17, 2011 9:33 pm ] |
technical support nailed it. i've had the g12 and used the cybercommander with it and ran into the same hiccup: live view settings in the menu disable firing a flash at the same time. In the canon 5d2 and 50d you have to turn off silent shoot in the menu so that the flash will fire normally. also: make sure you are not in continuous mode shooting as this will disable your hotshoe when using a canon point and shoot with an external hot shoe. |
