Sun Nov 20, 2011 7:43 pm
Many many years ago I purchased a flashpoint 1200 model strobe with a 5 inch reflector. At that time, accessories that were deigned for the Paul Buff 1200 mono-light series were compatible with the flashpoint mono-lights. Can the old 5 inch reflector on the flashpoint 1200 mono-light be replaced with a 7 inch reflector on the current model of White Lighting series? I am trying to purchase grids, beauty dishes that will fit this older unit. As funds permit, I do plan on purchasing a set of Alien Bees - 800.
Thank in advance!
The "Old Man" - Carl
Mon Nov 21, 2011 11:25 am
All of the modifiers we sell will fit on the Ultra models of flash units. I would expect anything else to fit on the Flashpoint, if the 5.5" reflector also does. However, not being familiar with the Flashpoint model, I hesitate to guarantee anything, just in case something is just different enough. If it has the four retaining fingers (or three like Balcar), then you should be fine.
Mon Nov 21, 2011 3:18 pm
Thanks, with :D quick responses such as this, I definitely plan on acquiring a couple of your new strobes - most likely the Alien Bees.
Thanks again!
The Old Man
