| White HOBD internal direct-light blocker http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2534 |
| Author: | juliamanalu [ Thu Nov 24, 2011 9:28 am ] |
| Post subject: | White HOBD internal direct-light blocker |
dear paul I am julia from indonesia.I lost the internal direct-light blocker for white HOBD 22 inch, and i lost the Diffusion Sock too..what size and what materials can be used if I wanted to make their own. Thank you Julia |
| Author: | Technical Support [ Mon Nov 28, 2011 11:09 am ] |
| Post subject: | Re: White HOBD internal direct-light blocker |
The light blocker can be made out of aluminium. The diffusion sock can be made from polyester or nylon, however most available fabrics will have brighteners in them which will cause fluorescing and cast a magenta blue color. |
| Author: | juliamanalu [ Sat Dec 03, 2011 2:43 pm ] |
Technical Support wrote: The light blocker can be made out of aluminium. The diffusion sock can be made from polyester or nylon, however most available fabrics will have brighteners in them which will cause fluorescing and cast a magenta blue color. thanks for information,i try to buy that from paulcbuff aussie but its realy expensive,that cost 100$ for that,i want to knw how inch is direct-light blocker? thanks |
| Author: | Technical Support [ Mon Dec 05, 2011 10:27 am ] |
It is 6 inches/15cm in diameter. |
