einstein 640 / PW TT1 / 5dmII
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=2557
Author:  drumsab [ Mon Dec 05, 2011 2:53 pm ]
Post subject:  einstein 640 / PW TT1 / 5dmII
Hi,
I'm using a Canon 5dmII with at PW TT1 (ver 6.0) along with Einstein 640's with the PW MC2 on it.
I'm trying to utilize the hypersync capability so I can use shutter speeds higher than 200 with the einstein.
I "think" I'm following the TT1 config instructions properly to do that but obviously I'm not doing something right since anything faster that 1/200 begins to show the "banding".
Does anyone know the TT1 config parameters that I need to use in order to make this work?
Author:  Technical Support [ Mon Dec 05, 2011 3:05 pm ]
Post subject:  Re: einstein 640 / PW TT1 / 5dmII
As HyperSync is a function of the timing introduced by the remotes, official help will need to come from Pocket Wizard. However, if any users want to chime in, they are welcome to.
Author:  chadwithuhc [ Mon Dec 12, 2011 4:45 pm ]
@drumsab I have the same setup as you (except TT5 instead) and I am trying to get higher speeds as well. I need to do some serious testing because I hear you have to really dial in the settings. After a lot of testing, if I find something I will let you know. But at the moment I have tried some settings and got speeds up to 1/500 with no banding. Unfortunately I don't remember what they are. :)
