Flash Triggers Repeatedly - why?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=260
Author:  matxutca [ Thu Feb 11, 2010 1:13 am ]
Post subject:  Flash Triggers Repeatedly - why?
I'm a newbie so looking for some assistance on what I might be doing wrong as I learn how to use my cybersyncs. Using Canon 580EX II and 430EXII, Canon 5dmii, and cybersync CST and CSRBs. When in AV mode with longer shutter speed, the flashes fire multiple times - about every 10 or so seconds and not necessarily at the same time. The initial flash is OK but wondering why the flashes repeat and not necessarily at the same time? I did look at my speedlight instructions and I do not have the flashes set to multi and they are set to M (manual) for 1/16 power in the case of last nights issue. What am I missing/doing wrong?
Author:  Shine [ Thu Feb 11, 2010 5:18 am ]
Post subject:  Re: Flash Triggers Repeatedly - why?
Hmmm.... have you accidentally turn on high sync mode in your flashes?
Author:  Technical Support [ Thu Feb 11, 2010 9:55 am ]
if the shutter stays open, the cst will fire once initially, then again once every 9 seconds. As to why they are not firng together, that is new to me. Will they fire together some, but othertimes not?
TS
Author:  matxutca [ Thu Feb 11, 2010 11:58 am ]
I don't believe I turned on the high-speed accidently - but I'll check tonight.
As for the 2nd reply on the "every 9 seconds" - could be that my 430EX can't keep up with the frequency. Is there anyway to NOT have it repeat?
Author:  Technical Support [ Thu Feb 11, 2010 1:53 pm ]
There is no way to keep it from firing again in 9 seconds. The 430 should be able to recycle to 1/16 in 9 seconds. The only thing i can think of to check regarding the non simultaneous triggering is that the speedlites are not in master or slave modes, also make sure the recievers are not in repeater mode (multiple rapid blinking green LED on the reciever)
TS
