FSB3240 and Speedring, can they be removed?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=263
Author:  tty007 [ Thu Feb 11, 2010 5:37 pm ]
Post subject:  FSB3240 and Speedring, can they be removed?
Hello there,
On the FSB3240, is it possible to change the Speedring for another one? as I would like to take my AB800 to light a background without any softbox and use one of my FSB3240 on a Aurora Camray C300 with its speedring.
Is it possible to use a different speedring on the FSB3240 that is not AB's ?
Best regards,
ghislain
Author:  Technical Support [ Thu Feb 11, 2010 5:43 pm ]
Post subject:  Re: FSB3240 and Speedring, can they be removed?
The outer speedring is permanently attached, however inner spedrings are available at the link below. I do not know what interface the unit you own uses, so i acannot say for sure one exists for your particular light.
TS
http://www.porters.com/flash-studio/lig ... s.html?p=3
pages 3 and 4
Author:  tty007 [ Thu Feb 11, 2010 5:53 pm ]
Oh but I could remove the Ab's inner ring and put mine (Aurora) Good. Thank you so much for your great support. I can't wait to get all my new Stobes and Softboxes...
Author:  Technical Support [ Mon Feb 15, 2010 10:35 am ]
maybe. Innerspeedrings can vary in size. our foldable softboxes' inner rings are 5.5" in diameter. Also, the link provided has the inner rings which ar 5.5" as well
TS
