Any probs using Cybersync w Viv 283's?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=268
Author:  david6101 [ Sat Feb 13, 2010 11:27 pm ]
Post subject:  Any probs using Cybersync w Viv 283's?
I dug an old (20 years) 283 out of the closet, and was wondering whether or not I would harm the Cybersync recvr if it happened to be one of the older ones that has the high voltage across the sync contacts...
Author:  CreV [ Sun Feb 14, 2010 6:06 am ]
Post subject:  Re: Any probs using Cybersync w Viv 283's?
CyberSyncs can handle voltages up to 300v.
Measure the voltage with a meter between the pins, while it's charging up and while it has full charge.
If it has voltages less than 300v it should be fine.
Author:  Technical Support [ Mon Feb 15, 2010 11:16 am ]
It is always a good idea to check, however we have users of old model flashes (particularly Vivitars) and i have yet to hear of a Cyber Sync unit getting fried when connedted to one.
TS
