Thu Feb 18, 2010 12:11 am
I didn't get a chance to test it out thoroughly yet but I did finally fire off some test pops. It worked fine, but I noticed once i did anything from about 1/4 power and up (White Lightning Ultra 1800) the green charge indicator LED would turn off for a decent 10 seconds or so, flicker red, before going back to green. I was curious as to if this is normal at higher power pops or if it might just be an issue with a fuse.
Fri Feb 19, 2010 10:32 am
When a good powered pop fires, the green LED can turn off for a while. The 1800 is a fairly high powered flash, and that does not seem unreasonable.
TS
