| Cybersync CST 10 FPS http://paulcbuff-techforum.com/viewtopic.php?f=8&t=294 |
| Author: | dhatcher [ Thu Feb 18, 2010 12:22 am ] |
| Post subject: | Cybersync CST 10 FPS |
If I have slightly older cst and csrb's with the 3fps, do I just need to buy a new cst with the 10fps capability to get 10fps or do I need to buy a new cst AND a new csrb to get 10fps? Thank you! |
| Author: | Technical Support [ Fri Feb 19, 2010 9:50 am ] |
| Post subject: | Re: Cybersync CST 10 FPS |
Only the CST would need to be replaced. All recievers can handle the 10fps. TS |
| Author: | korayus [ Tue Feb 21, 2012 4:37 am ] |
How can I understand which version is my CST? New or Old? Thanks in advance. |
| Author: | Technical Support [ Tue Feb 21, 2012 10:04 am ] |
If it has a gray flush test button, it is the later version with 10fps. A reddish brown raised test button is the older 3fps version. |
| Author: | korayus [ Tue Feb 21, 2012 2:12 pm ] |
Thank you very much. |
