| Connecting 3 lights to Vagabond Mini Lithium http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3179 |
| Author: | raki1974 [ Fri Dec 16, 2011 6:48 am ] |
| Post subject: | Connecting 3 lights to Vagabond Mini Lithium |
Hi All! Thanks for the great forum! Quick question: i have been using my vagabond mini Lithium with 1 Einstein and 1 AlienBee 800. I bought a SECOND Einstein and would like to use all 3 on the field with my Vagabond. What type of adapter do i need to buy to connect all 3 lights to the VML? (i bought an extra battery because i know 3 lights at the same time will drain my old one at a faster pace) Thank you in advance! Joel |
| Author: | Technical Support [ Fri Dec 16, 2011 9:57 am ] |
| Post subject: | Re: Connecting 3 lights to Vagabond Mini Lithium |
Any standard multi outlet adapter will work fine. Should be about $5 from pretty much any drug/grocery/hardware/discount store. |
| Author: | kenyee [ Fri Dec 16, 2011 12:05 pm ] |
raki1974 wrote: Quick question: i have been using my vagabond mini Lithium with 1 Einstein and 1 AlienBee 800. I bought a SECOND Einstein and would like to use all 3 on the field with my Vagabond In case you don't know...your recycle time will be slowwwwwww. The VML was designed for one per strobe usage.... If you want to strap that many strobes on a VB, you're better off w/ the VB2 and a splitter cord... |
| Author: | Luap [ Fri Dec 16, 2011 6:18 pm ] |
Recycle time depends on power levels. It's quite common to use three light setups in the 1/4 to 1/2 power range, in which case recycle times will be in a respectable 3 second or so range with a single VML. If all three are operated at full power you can expect around 9 seconds. |
