vagabond is shutting down
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3188
Author:  pessoa [ Tue Dec 20, 2011 3:47 pm ]
Post subject:  vagabond is shutting down
First of all , a big hi to everybody ...
The problem that is making me write this few lines is... my 2 vagabond are shutting down , i think i did everything in the right way. Charged the battery ( red light turned to green) all good until now, and then i connect it to the einstein and it turns on for 1 to 2 secs and then is shut down time , not only the flash but the battery as well. What is the reason for this to be happening. And its not only one is the 2 vagabond that i have .
The material is new (first time i tried , out of the box).
And let me tell , that this einstein , it kicks ass , i´m only starting to using it but i know it will help me making awsome photos ;)
sorry for my not so perfect english but is not my native language ...
All the best
* forgot to tell that the vagabond is the international version vm1 120-230v
Nuno Sousa
Author:  Technical Support [ Tue Dec 20, 2011 4:29 pm ]
Post subject:  Re: vagabond is shutting down
It is probably an issue in the batteries themselves rather than the inverters. You will need to contact the distributor from whom you got them for warranty claims.
Author:  pessoa [ Tue Dec 20, 2011 7:47 pm ]
Yes i think its probably an issue in the batteries cause i tried turning on the flash connecting the vagabond with the charger and the einstein worked like a charm... so i will contact the distributor.
All the best
Nuno Sousa
