| Use Mini Vag to charge Kindle Fire http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3201 |
| Author: | dphotoman [ Tue Dec 27, 2011 8:20 am ] |
| Post subject: | Use Mini Vag to charge Kindle Fire |
Any one know if it is safe to use the Mini Vagabond to charge the Kindle Fire using a USB cord plugged into the USB port on it? |
| Author: | BigIronCruiser [ Tue Dec 27, 2011 11:55 am ] |
| Post subject: | Re: Use Mini Vag to charge Kindle Fire |
Can't imagine why it wouldn't be safe, but that doesn't mean it will work. iPad's, for instance, can't be charged from the VML USB port. The sure way is to use the 110v charger that came with the Kindle. That's what I do with my dumbed-down (no Flash support) Apple devices. |
| Author: | Technical Support [ Wed Dec 28, 2011 11:13 am ] |
Safe? Yes. Again, whether or not it will work is a different story. The VML has a 5VDC .5A output. Many new devices require 5VDC and 1A output. Check the wall wart for its output specs. |
