Tue Dec 27, 2011 11:41 am
I want to use high flash sync speeds with the einstein. I have pocketwizard plusII. What is the minimum triggers I would need to shoot at high shutter speeds for sports like galbraiths examples http://www.robgalbraith.com/bins/multi_ ... 0053-10715
Would also like to control output of einstein. Assume for that I will need cybersync.
Thanks,
John
Tue Dec 27, 2011 12:36 pm
Hey John
Hypersync is not something that you will get from an Einstein. The fastest shutter speed I have been able to get is 320th ... but that's OK. You will get great action stopping ability via Einstein's incredibly short flash duration in Action mode. Einstein is the ticket for sports.
Any trigger will work just fine, I have Cyber Commander, PW Plus II's and PW TT1 / MC2's. I prefer the TT1/AC3/MC2 combination, but that's just me.
Tue Dec 27, 2011 1:08 pm
How then to prevent ghosting from ambient light? Need to shoot at least 500th and 800th would be better.
Tue Dec 27, 2011 3:07 pm
Studio strobes are usually powerful enough to be stronger than ambient, so you use the flash pulse to freeze motion.
The other alternative is to get a D70 or P&S (both w/ electronic shutter) w/ hotshoe to sync. On my LX5, I can do ISO80, 1/640 cleanly w/ Radiopopper JrX and an Einstein at 3/4 power...plenty to dim ambient...
Tue Dec 27, 2011 8:54 pm
I successfully tested the Einstein using the sync hack with pocketwizards and can shoot at up to 8000th of a sec using full power. Best results with a lower iso are obtained at about 2000th.
Fri Jan 27, 2012 8:52 pm
Where do I find this sync hack? I just got an Einstein with MC2 and a PW MiniTT1 for my Canon 7D, I am trying to figure out to setup or get hypersync. Any help would be great.
Sat Jan 28, 2012 11:51 pm
The hack should not be necessary with the powermc2. I used a pocketwizard plus to trigger the light. Discussed here
http://prophotocoalition.com/index.php/ ... peed_hack/
http://www.flickr.com/groups/strobist/d ... 362003933/
http://photo.net/photography-lighting-e ... rum/00YxXG
