Mon Jun 18, 2012 6:45 pm
Hi,
I wanted to buy some extra Anderson powerpole connectors so that I could run my Einstein off of a 50 ah 12V deep cycle battery. I was hoping you could specify which of the Anderson powerpole connectors is used on the Vagabond mini (e.g., part number or model name) and perhaps recommend a place to purchase them.
Jonny
Tue Jun 19, 2012 10:29 am
PP15/45 series commectors. The links for the components you need are below. There may be other outlets through which you can order them. Also, there is a specialized crimp tool that is required (or highly recommended) to attach them. We reccomend 12-14AWG wires, and run as short of a wire as possible.
http://www.powerwerx.com/anderson-power ... using.html
http://www.powerwerx.com/anderson-power ... tacts.html
http://www.powerwerx.com/anderson-power ... -pins.html
Tue Jun 19, 2012 1:20 pm
Thanks for the prompt reply.
Tue Jun 19, 2012 1:27 pm
Wow, the crimp tool I found on the site is >$200. Does PCB sell replacement cables for the Vagabond or charger that would already have the powerpoles crimped on?
Thanks.
Tue Jun 19, 2012 1:55 pm
No, we do no not. However, I have seen crimp tools in the $30 range and cheaper. Also, you can visit this link for ready made or ready to alter cables:
http://www.powerwerx.com/adapter-cables/
Users browsing this forum: No registered users and 25 guests
