| Cybercommander and CSR+ Not communicating with AB800 http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3226 |
| Author: | misterbill7718 [ Mon Jan 09, 2012 10:59 pm ] |
| Post subject: | Cybercommander and CSR+ Not communicating with AB800 |
I have a pair of AB800s and a Cybercommander connected with 2 CSR+. I can get them to trigger the lights with the mini-plug sync connections, but when I connect the telephone/data cables instead, the flashes will not trigger and start firing rapidly/uncontrolably. I do have a dummy plug in the sync jack. Does anyone have an idea what is going on? |
| Author: | Technical Support [ Tue Jan 10, 2012 10:07 am ] |
| Post subject: | Re: Cybercommander and CSR+ Not communicating with AB800 |
Sounds like a power supply issue. You could have noise on the AC line. Switching to a different circuit may isolate that as a problem. Also, a bad power strip, extension cord, or power cord can cause this as well. Since both lights are doing this, I would not suspect the power cords. I would suggest removing anything between the cords and the wall outlet to see if the problem persists. If not, you can then add back one component at a time to see when this behavior starts again. The last component added is the/a culprit. |
| Author: | misterbill7718 [ Tue Jan 10, 2012 12:40 pm ] |
Could this be caused by using "straight" phone cords instead of "crossover" cords? |
| Author: | Technical Support [ Tue Jan 10, 2012 3:49 pm ] |
Quite possibly, yes. |
