Fri Jan 06, 2012 9:39 pm
I have two VMLs; I just got them a few weeks ago, and I've used them once and they performed great. I notice that on one of the chargers (which I keep plugged in all the time as suggested), that the green light glows steady green when the battery is fully charged, but will flicker at a very high rate from time to time. I haven't noticed it on the other charger.
Not knowing what was causing the flicker, I turned on the battery while the ac adapter/charger was plugged in, then turned it off. The light now glows a steady green, its normal state.
This has happened a couple of times today, and I'm wondering if it's an indication of some problem with the charger.
Thanks in advance for some advice.
Fri Jan 06, 2012 10:20 pm
No. That is normal. However, it is not necessary to continually charge the VML, as they use lithium type batteries. The older V150/300 and VII should have a full charge maintained, but they use the older SLA technology. You can keep your lithium batteries in any state without harm.
Wed Jan 11, 2012 1:06 am
Great. Thanks for your reply.
Users browsing this forum: No registered users and 26 guests
