 [ 9 posts ]
Wed Feb 24, 2010 8:50 pm
I have been very happy with the CC and CST units. However, one issue that still plagues me is the slave for all of the units I have on CSBs fire whenever another photographer is shooting. I have the slave set to off for all units in the CC, but yet they continue. Do I also have to insert a dummy plug to stop this, or am I doing something wrong?
Wed Feb 24, 2010 11:12 pm
Cyber Commander can only disable slaves on Einstein and future lights. This capability is not in the AB interface. To disable AB/WL slaves, insert a blank sync cord or a "dummy" 1/8" plug.
Thu Feb 25, 2010 10:02 am
Ok, that is good to know. Thanks!
Thu Feb 25, 2010 10:04 am
I've got dummy plugs chained to all my AB and WL units:
Thu Feb 25, 2010 10:09 am
I think this is exactly what I am going to have to do. Thanks for the idea and the image.
Thu Feb 25, 2010 11:36 am
is this an optical slave? If so couldn't it be permanently covered up with black tape or something
Thu Feb 25, 2010 12:59 pm
since I never use the slaves I am considering disabling the thing completely anyway.
Sun Feb 28, 2010 5:43 pm
I got some dummy plugs from PCB, unscrewed the plug portion, cut off the connections, and stick into the socket.
"Permanent", but reversable...and nothing sticking out to catch on.
John
Mon Mar 01, 2010 11:20 am
Using the lock out function of the sync jack is recommended. Using tape will certainly make the eye less sensitive, but it can still fire. The eye is a sensor placed behind the white window. If the light comes in from a vent or other opening, it can still be seen, and therefore fire.
 [ 9 posts ]
Users browsing this forum: No registered users and 20 guests
