Sun Jan 22, 2012 9:56 am
I've noticed that every other photo seems to jump exposures. At first I thought my camera was set to bracket, but it's not doing this. It seems to be the flash output is varying? Is this something replacing the flash tube will fix? Or do I need to send it in for repair?
Sun Jan 22, 2012 11:54 am
This would not be a function of the flash tube. What power setting are you using and how fast are you firing? Also, are you using remotes, and if so which ones?
Sun Jan 22, 2012 4:12 pm
How long are you waiting between shots?
The flash will fire even if it's partially charged up....
Users browsing this forum: Majestic-12 [Bot] and 8 guests
