Cyber Commander/modeling lamp issue
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3233
Author:  Kaljam [ Thu Jan 12, 2012 10:41 pm ]
Post subject:  Cyber Commander/modeling lamp issue
I just got my Cyber Commander and a couple of CRS+ units today. I have two AB1600 units. I am having a problem with the modeling lamp control. The CC unit is triggering both strobes (and a Speedlight with a CRSB) so I know I have my channels and frequencies set correctly. I did go through the settings and specify the strobes as well as connecting them and plugging them in per the instructions.
I set the CC up so the AB's are channels 1 and 2.
I go into the LIGHT SETTINGS menu and then under MODEL MODE. When I choose the selection for FULL, ADJ or TRACK, both units work fine. But, when I set channel 1 for off, the model lamp on unit 1 goes to full brightness. When I set channel 2 for off, the model lamp on unit 2 shuts off correctly.
Likewise, I have channels 1 and 2 grouped. When I set that group for OFF, unit 1 goes to full brightness and unit 2 shuts off.
I swapped the CRS+ units and the problem is staying with the AB, not the CRS+ unit. So I am guess I have something bad in one of the AB1600?
Author:  Technical Support [ Fri Jan 13, 2012 10:00 am ]
Post subject:  Re: Cyber Commander/modeling lamp issue
Strange. This sounds like something you should probably call in about for more trouble shooting to really isolate the problem. Ask for David or Joe.
Author:  Kaljam [ Thu Jan 19, 2012 9:30 pm ]
A new set of modified receivers arrived today and everything works perfectly. PCB really was great in terms of customer service. Thanks.
