How to use the Cyber Commander as a lightmeter?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3253
Author:  xavierwallach [ Mon Jan 16, 2012 9:55 pm ]
Post subject:  How to use the Cyber Commander as a lightmeter?
MY question is going to sound quite stupid...
I still haven't figured out how to use the Cyber Commander as a lightmeter!
How do you guys trigger the Einsteins (I have two of them) if you are standaing at the subject's place with the CC in your hand?
I thought that pushing the meter button would trigger the flashes but it doesn't.
Can you please give me more info that what can be read in the user guide. It's quite vague.
Thank you for your help.
Xavier
Author:  Technical Support [ Tue Jan 17, 2012 10:17 am ]
Post subject:  Re: How to use the Cyber Commander as a lightmeter?
You would push in on the right hand joystick. If you have a single channel selected, only that light will fire (assuming the slave eyes are shut off). If you are in the ALL channel setting, all lights will fire. If you have GRP (it may look like GAP, but it is GRP for groups) selected, then one, some, all, or no lights may fire, depending on how the groups are set up.
Are you using the CC to trigger the lights from the camera, and if so, does that function work?
Author:  xavierwallach [ Tue Jan 17, 2012 8:39 pm ]
Well that was easy...
Thank you!
