Mon Mar 01, 2010 8:54 pm
I'm planning on buying a Vagabond II, and I'm wondering what is the best way to get my Vagabond II to last a long time. I'm only planning to use it once every two weeks or so. Is this enough? If not, should I use it regularly even when power outlets are readily available?
Cheers,
Mark
Mon Mar 01, 2010 10:56 pm
No need to use it regularly as long as you make sure you don't let it sit with a discharged battery for any length of time. If properly maintained, the battery will last around 500 charge/deep discharge cycles. If not used often, it should be charged overnight at least once per month, and immediately after a heavy-use session.
Wed Mar 03, 2010 3:42 pm
Thanks Luap!
