Fri Jan 27, 2012 5:14 pm
Is there a trick to changing the modeling light? I tried pulling but all I did was break the bulb.
So is there a release or something?
Fri Jan 27, 2012 5:58 pm
Push in, turn 1/4 turn counter clockwise, and let it come straight out. Just to be clear this is not the doughnut shaped glass tube, but is the bulb in the center?
Fri Jan 27, 2012 7:03 pm
Yeah, I figured it out after I found the instructions for installing a flash tube. I knew I was missing something.
Sat Jan 28, 2012 8:04 pm
Its also a good idea to wear gloves or use a paper towel to keep the oils from you hands off of the lamp.
Sun Jan 29, 2012 3:57 pm
Good call. I should have included that in my instructions.
Users browsing this forum: No registered users and 5 guests
