| ISO and Shutter Speed in Cyber Commander http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3313 |
| Author: | mr.software [ Fri Jan 27, 2012 3:38 pm ] |
| Post subject: | ISO and Shutter Speed in Cyber Commander |
I've looked through the forum and can't find an answer to this. Is there a way to set the ISO or Shutter speed in the cyber commander to something other than full stops? Seems I often want to shoot at 1/160, iso 7.1, for example, and I just have to do some math in my head to get things set properly. Thanks Don |
| Author: | Technical Support [ Fri Jan 27, 2012 4:16 pm ] |
| Post subject: | Re: ISO and Shutter Speed in Cyber Commander |
At this time, ISO and shutter speed are settable in full stop increments. Aperture values are displayed in 1/10 increments, and f/X.X' 3 and f/X.X' 7 are 1/3 and 2/3 equivilents. So 5.6' 7 would be the same as f/7.1. I guess you could set a +0.3f or +0.7f in the upper right corner under CAL. So ISO100 and +0.3f would effectively give you ISO 160. In a studio environment, shutter speed will not affect the metering function, so 1/125 vs 1/160 shutter speed will yield the same meter reading and the same captured exposure. |
