Einstein modeling light
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3314
Author:  gtguy256 [ Fri Jan 27, 2012 5:14 pm ]
Post subject:  Einstein modeling light
Is there a trick to changing the modeling light? I tried pulling but all I did was break the bulb.
So is there a release or something?
Author:  Technical Support [ Fri Jan 27, 2012 5:58 pm ]
Post subject:  Re: Einstein modeling light
Push in, turn 1/4 turn counter clockwise, and let it come straight out. Just to be clear this is not the doughnut shaped glass tube, but is the bulb in the center?
Author:  gtguy256 [ Fri Jan 27, 2012 7:03 pm ]
Yeah, I figured it out after I found the instructions for installing a flash tube. I knew I was missing something.
Author:  PowerEngineer [ Sat Jan 28, 2012 8:04 pm ]
Its also a good idea to wear gloves or use a paper towel to keep the oils from you hands off of the lamp.
Author:  Technical Support [ Sun Jan 29, 2012 3:57 pm ]
Good call. I should have included that in my instructions.
