Sun Jan 29, 2012 11:35 am
Do the Ultra 1800 units put out 1800 Ws.. is this accurate? Does anyone have the link to the original spec sheet (can't find it on the PCB website, and it's not in the manual pdf). Seeing as how the x3200 is listed at 1320 Ws I'm thinking this info is wrong..
Thanks!!
-Brandon
Sun Jan 29, 2012 4:51 pm
They are not 1800 true Ws. The 1800 specification was what we, and other manufacturers, called "effective Watt-seconds". This was a way to equalize comparisons between more efficient mono lights to the less efficient, but familiar, pack and head systems. We no longer use the term "efective Watt-seconds", though the naming of the Alien Bees and White Lighnting systems still reflect these.
Watt seconds are an inaccurate way to measure flash output, but is the universal specification for studio flash units (though should be accurate enough for lights within the same system). Lumen-seconds would be the proper units with which to measure and compare flash output directly, though we are the only manufacturer to publish lumen second specs.
***Updated*** Ultra 1800's are 900Ws lights.
Sun Jan 29, 2012 4:53 pm
Ultra series lights predate me by at least a decade, and I do not immediately recall the actual spec, though I believe it is 640Ws. (I will update this when I can access my references).
Thank you for that!! I would be grateful for the actual spec (when you have the time)!.
Mon Jan 30, 2012 10:09 am
Ok, so I was off by almost 50%. The U1800's were 900Ws.
Users browsing this forum: No registered users and 54 guests
