CC Group lights
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=334
Author:  Norm [ Fri Mar 05, 2010 8:09 am ]
Post subject:  CC Group lights
In any group setting can set up each light?
grp 1 channel 1 - 1/2 power, grp 2 channel 1 - full power, grp 3 channel 1 - 3/4 power.
or does the group just handle to power all ready setup but just turn off lights in different group.
Author:  Technical Support [ Fri Mar 05, 2010 9:47 am ]
Post subject:  Re: CC Group lights
grouping will change between sets of lights, but any power setting remains. You can, however, save it as a set up and switch between the set ups. When you open from that set up, it will retain whatever setting was saved as that set up.
Author:  Norm [ Fri Mar 05, 2010 2:22 pm ]
I think if you can have each channel level setting for each group wouldn't that be how CC should be beside saving and opening for different levels in the group setting ? White background grp 1 backlights set to high, or color backgroung grp 2 lower background lights ect, sorry but I think there one step missing here.
Author:  Technical Support [ Fri Mar 05, 2010 2:59 pm ]
The grouping function is designed to treat a group of lights as one. like two lights on the a white back ground. It is to have them raise and lower together.
Changing the set would require a change to the set up in the CC
Author:  Luap [ Fri Mar 05, 2010 5:35 pm ]
What you're asking for sounds simple but would require a complete revision of CC architecture, more processing power, more cost and more complexity to an already complex device. The best way to handle this is to do what tech suggest . . . create different presets for different light balance . . . high key, low key, etc.
