| fan only http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3350 |
| Author: | jbeane [ Tue Jan 31, 2012 7:32 pm ] |
| Post subject: | fan only |
I have a AB 1600 and only the fan comes on does not charge and no modeling light (swapped out modeling light bulb) the red light in the switch works also does it need to be sent back for repair or is this a problem that can be fixed by the user. some kind of reset or somthing? I have cycled the power switch/cucirt breaker. Thanks John |
| Author: | Technical Support [ Tue Jan 31, 2012 7:54 pm ] |
| Post subject: | Re: fan only |
Are you using the RJ11 telephone jack? |
| Author: | jbeane [ Tue Jan 31, 2012 8:01 pm ] |
Technical Support wrote: Are you using the RJ11 telephone jack? no just plugged in power cord and only the fan and red switch light come no modeling light and no charging of the flash john |
| Author: | Technical Support [ Wed Feb 01, 2012 11:52 am ] |
That sounds like the unit will need to come in for repair. Please contact Customer Service to make arrangements. |
