Mix Einstein 640's and White Lightnings
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3366
Author:  onetrack97 [ Sat Feb 04, 2012 9:28 am ]
Post subject:  Mix Einstein 640's and White Lightnings
My studio uses White Lightning X1600's wired with LG4X remote. The lights all have 250 W modeling lamps.
Now I'm adding two Einsteins with Cyber Commander to use as the main and fill lights.
They now come with 150 W & 250 W modeling lights, but they recommend 150 W due to heat.
I'm firing all of them with CST's. The X1600's will not be controlled by the CC.
Is anyone sticking with the 250 W bulbs?
I see that I can wake the Einstein up via the CC. Is there a way to put them to sleep with the CC?
Thanks,
Scott
Author:  Technical Support [ Mon Feb 06, 2012 5:35 pm ]
Post subject:  Re: Mix Einstein 640's and White Lightnings
Thanks,
Scott
You can go to SETUP>LIGHTSETTINGS>(CH=ALL) POWER=STANDBY
You can also save a set up with the lights off, then just open that memory setting when you need the lights off. If you temporarily need them to not fire, you can change to a group setting where they are not selected from the main screen.
