 [ 12 posts ]
Fri Feb 10, 2012 2:02 pm
i have to b800s and the Cyber Commander for about a year now, but i dont use the light-meter or changing power functions from the transmitter b/c i dont know how, i read the manual a few times but its still quite confusing to me, r there any good in depth tutorials anywhere or videos that can show me how to use my Cyber Commander to its full potential?
Fri Feb 10, 2012 3:02 pm
Do you have a CSR+ or CSRB+ connected to your B800? Had to ask first in case you were trying to control power w/ stuff you can't control power with :)
The CC should be fairly easy to use...I fiddled with it w/o reading the manual and didn't have a problem controlling power or the modeling lamp power, so what are you exactly being stuck on?
And where are you located? Someone nearby might be able to walk you through some of it to make it easier...
Fri Feb 10, 2012 3:11 pm
We do not have an official videos on Cyber Commander. However, there are several on the web at places like YouTube. If you prefer to give us a call, we can walk you through the set up and operation.
Fri Feb 10, 2012 3:21 pm
thanx, im using both the cyber comander and csrb recievers, i got it to work but it just seems very confusing going through menus and stuff i guess i just have to spend more time playing with it, for now i just use a cst to fire my strobes, i live in Far Rockaway Ny
Sun Feb 12, 2012 11:05 am
Just to be clear, you mean the CSRB+ receivers, right?
The CSRB will only trigger, not control power...
Tue Feb 14, 2012 3:13 pm
yes im using csrb+ , i did get it too work before im just not so familiar enough to use it for events yet so im just using the trigger part with out the rj11 cords
Wed Feb 15, 2012 5:21 pm
Conceptually, you do this since you're using B800's:
- tell the CC what is on each channel (put a sticky on each of them and a CSB+ labelled "1", "2", etc. for the channel#)...you do this by selecting the channel w/ the left joystick and then switching to the configure menu w/ the right joystick
- once that's all set, you should only need to use the left joystick in normal operation. Flip through channels w/ it, and adjust each channel's power w/ it.
Keep those two things in mind and it becomes pretty simple. The key to keeping it simple is to label your B800 and associated CSRB+. With Einsteins, you only need to label your Einstein since you configure the channel on the Einstein itself and it magically identifies itself to the CC when you do a refresh.
Thu Feb 16, 2012 2:17 pm
Thanx Kenyee!
Mon Apr 30, 2012 4:39 pm
Seems that I am in the same boat. The more I read the instructions the more confused I seem to get. Wondering if anyone is close to Santa Fe, Texas to give me a hand on getting a handle on programming the cc and lights.
Wed May 02, 2012 10:52 am
While I am not in Texas, you are welcome to give us a call, and we will be more than happy to assist you with the Cyber Commander.
 [ 12 posts ]
