| Mini Vagabon stand clamp - Solution http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3429 |
| Author: | John Skinner [ Wed Feb 22, 2012 7:22 am ] |
| Post subject: | Mini Vagabon stand clamp - Solution |
Although some will say this thread is useless without pictures, I'm certain people with these clamps will be able to place 2 -2 together by way of description and get this sorted. I have been wrestling with the slipping issues on these clamps for sometime now and just had not sat down to work it out. I found rubber similar to this... http://www.amazon.com/Butyl-Rubber-Shee ... B000MAL0K2 Although mine is somewhat thicker and more sponge based, I used contact cement to glue this to both sides of the clamp. The C (curved side) and then against the flat (Battery) side, trimmed after drying with a new razor knife blade. Since this application I've had ZERO slippage either high or low mounted on the stands. I have tested this in -10 to 85 degree weather and I can claim it to be a usable, viable and permanent fix for this issue. |
