Sat Mar 17, 2012 5:18 pm
Hi all,
I hope someone can help me out. I have an Einstein on channel one and AB800 on Channel two. Whenever I change channels (either to change on or two channel 2) the einstein powers off. Any thoughts?
Thanks,
Ken
Sat Mar 17, 2012 6:37 pm
My guess is they are set to STANDBY in the Cyber Commander, and were turned on via the back panel. CC will override the settings made on the back panel. While there are several steps to turn the lights on and off, once a set up is created and saved, switching between setups is more effecient.
The steps to turning on the Einstein via the Cyber Commander and saving as a set up are as follows:
TURNING THE LIGHTS ON
-Press any joystick in any direction on the Cyber Commander to wake it up.
-Once awake, use the left joystick left and right to select the ALL channel setting.
-Use the right joystick left or right to scroll to the SETUP screen
-Use the right joystick up or down to highlight LIGHT SETTINGS, then press in with the right joystick
-Use the right joystick to highlight POWER
-Use the left hand joystick UP or DOWN to highlight ON.
(be careful to not use the left joystick left or right, or you will change channels)
-The lights should now be ON
-Repeat the above save proceedures to save this new configuration. Be sure to select a new (white) SD location when saving.
SAVING YOUR CURRENT SET UP
-Use the right joystick left or right to return to the SETUP SCREEN
-Use the right joystick up or down to select SAVE AS, then press in with the right joystick
-Use the left joystick to select an internal or SD card save location (Internal1, SD50, etc). Used SD locations will appear in blue, open/unused SD locations will be in white. All Internal save locations will be white, so be careful to not overwrite a set up accidentally.
-Rather than starting with SD1, I recommend saving locations with SD50, and working "backwards". This will be quicker to access when recalling a saved set up than SD1, due to the individual channel settings in the OPEN MEMORY screen.
RECALLING A SAVED LOCATION
-Use the right joystick to the left or right to enter the SETUP screen.
-Use the right joystick up or down to select OPEN MEMORY, then press in on the right joystick
-Use the left joystick left or right to select the saved memory location you wish to recall
-Press in on the right joystick, the display on the Cyber Commander, as well as the lights, should reflect the changes between set ups.
