| Is there a diffrence in color temperature http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3474 |
| Author: | rodney [ Wed Mar 21, 2012 7:58 am ] |
| Post subject: | Is there a diffrence in color temperature |
Is there a difference in the color temperature between einstein 640 at half power and a AB800 at half power. |
| Author: | Technical Support [ Wed Mar 21, 2012 10:46 am ] |
| Post subject: | Re: Is there a diffrence in color temperature |
Yes, but the difference is smaller than what you would find between two different modifiers. An E640, with dome, would be about 5300K, without it would be 5600K while a B800 at 1/2 power would be about 5520. Each spec is assuming no other modifiers. |
| Author: | rodney [ Thu Mar 22, 2012 3:07 pm ] |
Technical Support wrote: Yes, but the difference is smaller than what you would find between two different modifiers. An E640, with dome, would be about 5300K, without it would be 5600K while a B800 at 1/2 power would be about 5520. Each spec is assuming no other modifiers. Thank you for your response |
