| X3200 Beeps but no Pop http://paulcbuff-techforum.com/viewtopic.php?f=8&t=348 |
| Author: | Two23 [ Tue Mar 09, 2010 7:08 pm ] |
| Post subject: | X3200 Beeps but no Pop |
One of my X3200 lights isn't working. I plug it in to AC and the green ready light comes on, then begins a series of slowly blinking. Blinks once about every ten seconds or so. when I push the "dump/test" button it only beeps at me. No flash. I tried the low power setting and still no Pop. The modeling light is working fine. There are no triggers plugged in. All my other X3200 units will fire every time I hit the red test button. What's up? Should I open it up and start poking around inside with a steel screwdriver to see if I can get it to do something? Kent in SD |
| Author: | Technical Support [ Tue Mar 09, 2010 9:05 pm ] |
| Post subject: | Re: X3200 Beeps but no Pop |
swap flash tubes with a known good light. If the problem persists with the light, it will likely need to come in. If the problem follows the tube, a new flashtube will fix the problem. |
| Author: | Two23 [ Wed Mar 10, 2010 12:14 am ] |
Dang you're good. Definitely the tube. I was afraid the thing was fried and I'd have to send it in. I"ll order a new tube tomorrow. Kent in SD |
