| larger micro sd card for Einstein firmware updates? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3487 |
| Author: | DJP [ Wed Mar 28, 2012 10:18 am ] |
| Post subject: | larger micro sd card for Einstein firmware updates? |
Can a larger micro sd card (for example 8gb) be used to update the firmware on an Einstein if it is partitioned to 2GB? |
| Author: | Technical Support [ Wed Mar 28, 2012 11:55 am ] |
| Post subject: | Re: larger micro sd card for Einstein firmware updates? |
Most likely, if the card is partitioned and formatted properly (FAT16). However, we have not yet tested that, so I would not advise doing so at this time. I will locate a larger SD card and do some testing, reporting back here what I find. |
| Author: | DJP [ Wed Mar 28, 2012 12:03 pm ] |
great- thanks! |
| Author: | Technical Support [ Fri Mar 30, 2012 4:45 pm ] |
Just to update you, I found a larger card to test with. Turns out it was defective (heated to extreme temps in the card reader). Gonna get another. |
| Author: | DJP [ Tue Apr 10, 2012 3:59 pm ] |
just wandering if this is still being looked into- thanks! |
| Author: | Technical Support [ Wed Apr 18, 2012 1:34 pm ] |
So far, we have tried, but have not been sucessful in doing so. |
