Possible to convert White PLM Umbrellas to Silver use Cover?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3490
Author:  liography [ Fri Mar 30, 2012 1:40 pm ]
Post subject:  Possible to convert White PLM Umbrellas to Silver use Cover?
Hello,
I just bought the White PLMâ„¢ Umbrellas with all 3 cover accessories, I noticed that the Black Outter Cover is actually silver, is it possible to just take the existing shot through white cover off and put the silver cover on to convert it into a silver PLM umbrella?
Just curious if it's do-able..
Thanks!
Author:  Technical Support [ Fri Mar 30, 2012 3:32 pm ]
Post subject:  Re: Possible to convert White PLM Umbrellas to Silver use Cover?
Not really. First the white fabric is sewn to the frame of the PLM. This would have to be cut and re-sewn. Additionally, the silver fabric is sized slightly larger than the white in order for it to fit over the white, so it would not fit properly on the frame.
If you prefer silver over white, you can return the white within 60 days and order the silver instead.
