Einstein power cord loose and sounds like it is shorting
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3497
Author:  davstr [ Sun Apr 08, 2012 5:20 am ]
Post subject:  Einstein power cord loose and sounds like it is shorting
I recently purchased 5 Einsteins, I'm in Dubai on 220V power, and each and every one of my power cords is loose and sounds like it is shorting if any movement affects the connection.
Is this normal?
If so, is this not something to be worried about?
Is there a solution to this problem?
David
Author:  TechNiko [ Sun Apr 08, 2012 1:32 pm ]
Post subject:  Re: Einstein power cord loose and sounds like it is shorting
My Einsteins came with loose power cords too.
I had to replace them because they kept coming off, especially when hand-holding lights with a vagabond-mini belt. Any other power cord I had laying around was a much snugger fit.
Author:  davstr [ Sun Apr 08, 2012 2:20 pm ]
Frustrating. Thanks for sharing your experience.
Author:  JakAHearts [ Tue Apr 10, 2012 9:28 am ]
If I wiggle my cord, it makes a electric sound, like static electricity when you get a blanket from the dryer. It does take effort to remove it though, so Im not worried about it.
Author:  Technical Support [ Tue Apr 10, 2012 10:01 am ]
Is this normal?
David
Are these Schucko cords or the US type cords?
Author:  davstr [ Tue Apr 10, 2012 10:22 am ]
Not sure what you mean by Schucko, but I purchased my equipment in the US, and shipped them to Dubai. Sounds like they are the US cords?
Author:  Technical Support [ Tue Apr 10, 2012 10:30 am ]
Schucko is the style of plug that is used frequently on 240V mains outlets. But if you are using the cords that came with the units, which came direct from us, that tells me what I need to know.
