| Einstein flash unit will not power on http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3499 |
| Author: | davstr [ Sun Apr 08, 2012 5:24 am ] |
| Post subject: | Einstein flash unit will not power on |
I recently purchased 5 Einsteins and today during a shoot, one of the units stopped working. It does not power on whatsoever. I'm in Dubai on 220V power. Is there a troubleshooting suggesting for this? David |
| Author: | PowerEngineer [ Mon Apr 09, 2012 10:25 am ] |
| Post subject: | Re: Einstein flash unit will not power on |
I would start by switching the power cord with a working unit to eliminate the cord as a suspect. Then check the E-640's fuse. An easy way to check is to swap it with one from a working unit. |
| Author: | davstr [ Mon Apr 09, 2012 11:06 am ] |
Done and done. It was the first thing I checked, as well as the wall sockets. Also checked the flash tube to make sure it was seated properly as well as the modeling light. Still nothing. Dead. |
| Author: | Technical Support [ Tue Apr 10, 2012 10:21 am ] |
If the unit will not power on at all, remove any remotes from the top and any memory card, should one be installed. At this point, only a power cord and a fuse are the only possible user replaceable solutions. If the unit turns on, then the flash tube could be suspect. If these do not solve the problem, then you will need to contact the distributor from which it came for warranty service. |
