CSR not triggering flash.
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=3501
Author:  Kevyn [ Mon Apr 09, 2012 10:25 pm ]
Post subject:  CSR not triggering flash.
I have the CSR and the AB400. My CSR isn't triggering the flash when I press the test button. The sync cord is connected. Any thoughts? :/
Author:  Technical Support [ Tue Apr 10, 2012 8:05 am ]
Post subject:  Re: CSR not triggering flash.
First off is CSR green LED blinking once you plug in the AC cable? If so does the green LED blink red when you press the CSR test button? Does the sync cable plug securely inside the CSR sync jack? If so, and the red LED blinks when triggered, then try a different sync cable. Can I assume the B400 will fire if you press the red test button on the back panel?
